11-18-2024 05:58 PM
Just switched to public mobile from virgin. I cannot send or recieve text messages. I can receive calls
11-18-2024 09:04 PM
try reset all networks
and if Android, clear cache or clear data of the messaging app
11-18-2024 07:28 PM
hi @Jeff43 this step could take long. Patience is the key
11-18-2024 07:27 PM
Text received and yes sent days ago. Since then texts don’t send or receive
11-18-2024 07:26 PM
Trying to verify phone number.
11-18-2024 06:48 PM - edited 11-18-2024 06:48 PM
Did you reply to the text with YES from Virgin confirming you are porting over to PM?
If you missed this step, you need to contact a CS_Agent to contact Virgin to resend you the text.
11-18-2024 06:08 PM
hi @Jeff43
iPhone? Remove the phone number from iMessage sertings , and reboot
When phone is back, go back and enter the phone number to re-register
