Purchased the wrong add on
Ronile
How do I cancel it?
I can't find how to reach the support agents (human)
Thanks,
Roni
Hi @Ronile
although PM is prepaid and usually do not issue refund, but if you have bought the wrong addon and haven't use it yet, have support agent to review and they can likely fix it, or change it to the correct one for you
 please submit a ticket with CS Agent here:
Sansan
Cannot be done but send a message to customer service representative and see if they can do it for you.
Message below link
@Ronile  You can’t . You will need to engage support and ask them if they can reverse it for you and buy the proper add on
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
