11-26-2023 03:25 PM
I purchased a 15 day usa add on of talk, text, and data yesterday. I've reset all systems. I've turned things off and on again. I've restarted phone. I've tried AT&T and t-mobile. The data image at the top of my phone is on and showing a network with availability but no data is being sent or received. The other parts of my usa add on package (calling and texting) are working fine
11-26-2023 09:32 PM
Wow. What a system mistake that is. Here is a link to a CS Agent. Show them this screen shot that you purchased it yet it's not on your account.
They should be able to fix it right away since it's now almost 9:30am there.
11-26-2023 05:22 PM
11-26-2023 05:16 PM
I called *611 to access public mobile which states i have not purchased a usa add on. My on line account says the same. However my account shows my purchase receipt for the add on and my credit card shows the purchase.
11-26-2023 05:14 PM
Update #2 - I called *611 to access public mobile which states i have not purchased a usa add on. My on line account says the same. However my account shows my purchase receipt for the add on and my credit card shows the purchase.
11-26-2023 05:09 PM - edited 11-26-2023 05:11 PM
Can you go to your account and confirm you actually purchased the data roaming plan and not just the talk/text plan?
Does your APN say this? isp.mb.com ??
11-26-2023 05:05 PM
I'm not an Android guy but Google tells me this.
Please note: If the Data Roaming switch is greyed out, check that Mobile data is activated. Go to Settings > Connections > Data usage > Mobile data.
You will now be able to use mobile internet when abroad.
11-26-2023 04:05 PM
Thanks for your siggestions.
Android Samsung
Yes tried AT&T - no success
Yed tried rebooting about 5 times now both yesterday and today
volte is enabled
Mobile data is enabled
11-26-2023 04:00 PM - edited 11-26-2023 04:02 PM
This is going to make me look stupid but.... did you try AT&T? and rebooted?
Oh. What phone do you have? Have you enabled VoLTE on your phone? Turned on Mobile Data settings?
11-26-2023 03:58 PM
Update - it's definitely a network error but restarting, resetting network, turning off and on is not resulting any change. Texting is working but talking is not.
11-26-2023 03:56 PM
No no reason. The network should be t-mobile but as I'm getting a network error I was trying different available network
11-26-2023 03:55 PM
Thank you. I've now tried to change per your suggestion but no change. I am getting a network error.
11-26-2023 03:54 PM
Thank you. I've done that 3 times and just again now from your advice. No change but you're correct It's a network error.
11-26-2023 03:46 PM
I have been in the US twice in the last 2 months. T-Mobile has better reception and reliability. Perhaps it could be just the locations I am attending. But even my co-worker who went to Vegas last weekend said T-Mobile was better for reception and service.
11-26-2023 03:36 PM
Out of curiosity, is there any reason to use AT&T? Is it just there in case TMo has bad coverage?
11-26-2023 03:26 PM
I've seen comments you may have to force 4G/LTE not auto 5G or whatever it's called. Can you try that?
