Purchased 3GB US Data (15d) Doesn't Work
Public_Tel_2023
Purchased 3GB US Data (15d) and it didn't work. Didn't even connect to AT&T network. 27 bucks down the drain. And it expires too!
Got an iphone? Were you connected to ship wifi? Were you sailing through Canadian waters when it would work?
Public_Tel_2023
Yes, it was in Alaska. I got the refund as a credit. Oddly texting worked on a ship.
@Public_Tel_2023
per chance were you in Alaska ? The roaming app will not work at all in that state. Send a private message to a CSA using this link. They'll likely credit your PM account.
Public_Tel_2023
Yes of course had Data on and Roaming On. I only saw the AT&T network but it wouldn't connect or work. There was no T-Mobile network that I could see.
I will reach out to the CS_Agent.
@Public_Tel_2023
PM has a contact with T-Mobile and not AT&T. Don't know why you want to connect to AT&T.
Contact a CS_Agent by private messaging on your computer on the envelope icon for a credit.
Priority
Did you have Data Roaming and Roaming Settings enabled?
I always thought Public Mobile used T-Mobile when in the United States.
If you Add-on wasn't used as a result of Public's error, I'm sure the customer service agent will be able to remove it and give you a refund in Account Credit.
Have you already reached out to the CS_Agent?
