01-21-2020 08:52 AM - edited 01-05-2022 09:07 AM
Does anyone else get a blank "Browse" section when clicked on? Its been this way for a few days now. I thought it would have cleared up by now.
01-23-2020 05:09 AM
@Joelkim wrote:
I think the samsung browser is problem. did you try on your laptop?
Already answered https://productioncommunity.publicmobile.ca/t5/Self-Serve/Public-mobile-main-page-glitch/m-p/488339/...
01-23-2020 04:05 AM
01-21-2020 10:17 AM
Sometimes the good old "Turn it off and Turn it on again" works for me. I use Safari.
01-21-2020 09:34 AM
Thanks @Jb456 reinstalling Firefox did the trick.
01-21-2020 09:24 AM
I guess my last choice is uninstall Firefox and reinstall. Thanks for all the help and suggestions. Hopefully this will work.
01-21-2020 09:20 AM
@darlicious wrote:It appears the problem is related to Firefox. Works fine on Google and chrome. If theres an update for Firefox where would I find it?
Sorry, it something on your end. Firefox on PC and mobile both working fine for me. Ditto with Chrome, brave browsers.
01-21-2020 09:15 AM
If tablet is a android. Open Google Play store..click three lines and go to "my apps & games" in there you can click the button to search for updates.
Also you could export your book marks if you have any ...uninstall Firefox ..reinstall a fresh copy and import your book marks back...that should solve issue.
01-21-2020 09:10 AM - edited 01-21-2020 09:10 AM
01-21-2020 09:04 AM
Working fine on my phone in chrome. I'll clear my cache on Firefox on my tablet and report back.
01-21-2020 09:02 AM
mine is fine as well.....Chrome. Most likely browser issue.
Reboot should clear it up
01-21-2020 08:59 AM
Works in IE and Chrome. Trying clearing your cache and cookies then reboot.
01-21-2020 08:59 AM
No. Try clearing your cookies /browser cache.
Also check if there is any updates required. Not sure if you're using Chrome browser but there was an update yesterday.
Mine is working on both mobile and laptop.
01-21-2020 08:58 AM
Working well here. It's likely your phone (memory / cache issue?). Restart or cleanup might help.
Maybe try with another device?
01-21-2020 08:57 AM
My website working. Using Safari on Macbook.
