02-09-2023 06:42 PM - last edited on 02-10-2023 09:28 AM by Dunkman
I Joined last year and my phone was screwing up this Feb so I went to Walmart to buy another, the guy said I couldn't buy outright and had to go with another carrier. So I said what about Public Mobile and all the great humanists that helped me out, I will have to buy elsewhere to remain with Public Mobile and all the great people.
02-10-2023 09:05 AM
Gm, yeah it's Pixel 7 I was a little disappointed 6 doesn't charge wirelessly and you have to buy a charging piece so had to go $200.00 more as I already have a wireless charger. The only thing a bothered me about setting up is it kept giving me weather notification updates every 30 minus 1/2 day looking threw settings google assistant finally found the weather setting and it just said Fahrenheit or celsius gerr. So I had to turn off notifications other than that you are right it does a lot and is a nice android.
02-09-2023 09:32 PM
@webspy007 wrote:I went to best buy and got google phone, I like Public mobile as I use my cell like a landline never take it out so don't want to pay high fees like the others you hagn
@webspy007 you can't get better Android phone than a Google's. Good Choice
Which Pixel is that?
02-09-2023 09:30 PM
tyvm got a google it seems nice you hagn
02-09-2023 09:28 PM
02-09-2023 09:26 PM
Yes, most retailers try to go on a higher plan with another carrier.
If you are on a budget, you can go with a certified pre-owned phone from PM or Mobile Klinik. There are new Motorola Moto G phones at Costco as noted @softech.
There are also iPhone SE (2022), 13 or 14 at Costco.
02-09-2023 07:12 PM
@webspy007 Walmart guy was trying to make money
so, you need a new phone? did you check OM CPO phones?? or get outright from local Costco
