02-10-2023 08:31 AM
Would like to change providers and need to get permission to keep my number
02-10-2023 09:44 AM - edited 02-10-2023 09:49 AM
02-10-2023 09:17 AM
@HALIMACS wrote:Permission granted.
But wait @monababb , can we convince you to stay?
What needs fixing or improving?
LOL @HALIMACS
Watch out @monababb - Halimacs is no Public Mobile representative; although a good source for help otherwise. 😉
If you are porting your Public Mobile number to another provider, the OTHER PROVIDER is the one you need to deal with to arrange all the porting details. Ensure with them that your number is portable to their network, and if your Public Mobile account is active, they will take of the rest to do the transfer over to them.
See Get Help Article on transferring/porting OUT:
02-10-2023 08:45 AM - edited 02-10-2023 09:07 AM
Permission granted.
02-10-2023 08:35 AM
@monababb trying to port out?
But first, make sure your PM account is currently active and you can receive text without problem. Login to My Account and get the account number from Profile page
While you are at My account, you might want to also disable Pre-Authorized payment just in case.
Then activate your new line with your new provider and request to port a number. Provide them PM's account number as the porting information
this is critical: Then still have your PM sim card in the phone, wait for PM to send you a text to confirm your porting request. You need to reply YES within 90 mins
After you replied yes, you can put your new sim card in the phone and wait until you get incoming calls. Once you are getting incoming calls, porting is completed. Your PM account will also be closed at this stage (you will no longer be able to login to PM My Account after)
02-10-2023 08:35 AM
@monababb @Info on porting number
When transferring (porting) your number to any new carrier it’s important to remember to leave the old providers SIM card in the phone until you receive the confirmation text from old carrier @that point you have 90 mins to reply YES to the confirmation text … also when going thru this process the new provider will want you old providers account number and will ask for IMEI number disregard this (IMEI) number as it has a tendency to just cos porting hiccups .. so if your ready to port to pm and already activated a SIM card you can go to your self serve serve profile tab and change /transfer (port) number this can also be done on activation but it’s advised to pick a temp number first then port
02-10-2023 08:33 AM
So what's your question?
