03-26-2019 02:56 PM - edited 01-05-2022 06:59 AM
I'm wondering if anyone is either using Public Mobile in the more northern areas of BC (ie: Fort Nelson/Fort St John etc), or travelled there and what is/was their experience in using their phone services or data reception?
Another question would be if anyone knows if there a lot of dropped calls with Public Mobile vs Telus?
Thanks.
03-27-2019 01:53 AM
@dabr wrote:@ZfromVanC Yes same network but was wondering if Telus calls take priority at certain times..
Telus claims there is no priority on what uses it's network. I have not been able to prove otherwise.
One of Public Mobile's perceived shortcomings, is it's "slow" 3G speed LTE. With a lot of rural towers, that is the best speed you can get, no matter what carrier you use.
03-26-2019 05:00 PM
@computergeek541thank you!
03-26-2019 04:56 PM - edited 03-26-2019 04:57 PM
@dabr wrote:@skifanThanks...just what I needed to know.
Ooops...I was trying to accept @skifan latest post as solution, but seem to have accepted my own answer instead...anyone know how to fix this?
Z10user4 has explained how to do this by using the individual messages's menu and selecting "not a solution".
I've already made the change for you.
03-26-2019 04:54 PM
03-26-2019 04:28 PM - edited 03-26-2019 04:40 PM
03-26-2019 04:24 PM - edited 03-26-2019 04:24 PM
Yes....I did use data extensively.....in fact I had to Hot Spot my data so that my Rogers based companions could access the internet. ( I managed to get a couple of referrals from them when they subsequently switched over to Public.)
03-26-2019 03:59 PM
@skifan Thanks..that's what I was hoping..did you use data as well as your phone service when you travelled throught that region?
03-26-2019 03:56 PM
I have travelled extensively in the Ft. St. John, Dawson Creek, Chetwynd, Tumbler Ridge area and can confirm that coverage is actually quite good. My travelling companions who are using the Rogers network have significantly poorer results.
03-26-2019 03:41 PM
@hycm53 I just tried your suggestion and it shows coverage in those areas..thanks.
03-26-2019 03:39 PM
@srlawren Thanks that's good to know!
03-26-2019 03:38 PM
@dabr no, there is no prioritization between the brands, as per our resident expert @sheytoon
03-26-2019 03:35 PM
@dabr On the map, enter address or city name, for instance Fort Nelson BC, it showed up saying "Your location has coverage."
03-26-2019 03:26 PM
@hycm53 Thanks, did notice there seems to be no difference in the map coverage, but hoping someone who has been in the region can verify there was no issue.
03-26-2019 03:23 PM
03-26-2019 03:03 PM
PM's coverage as same as Telus. You may check it out:
03-26-2019 03:02 PM
@Anonymous Yes I see the coverage map shows the same, was hoping is anyone has been there and had no issues though..thanks for replying.
03-26-2019 03:01 PM
@dabr wrote:I'm wondering if anyone is either using Public Mobile in the more northern areas of BC (ie: Fort Nelson/Fort St John etc), or travelled there and what is/was their experience in using their phone services or data reception?
Thanks.
Public Mobile runs on the Telus network, so the coverage is the same as you would get with Telus.
03-26-2019 03:00 PM
Thanks.
Way down on the bottom of this page is a link to the Coverage Map. It's really just the same as Telus. It looks like that northeast corner is reasonably covered.
