Public Mobile overseas talk/text
3813
I will be using my Public Mobile plan (with sim card in my  iPhone) while travelling to China and HKSAR,  will I be able to receive calls (talk)/ text messages originated  from Canada?
@DennyCrane  appreciate your correction. Looking at the map you are 100% correct, so from now on my comment will be 'Canada+USA only'.
@Meow I understand the point you're making, but to clarify North America includes countries such as Mexico, Greenland, Costco Rica etc, which there are no roaming agreements for. You can only use PM service in Canada and the US.
dust2dust
So the first part of your sentence, no you won't be. 🙂
Not using the Public service. But you could forward calls and texts to the previously mentioned voip app. Then with local wifi or cell data service, answer and make calls and receive and reply to texts using the voip number (not the Public number by the way).
Chalupa_Batman
Hi @3813
As per @Meow Public Mobile only works in Canada and the United States. The only real option you can do is to purchase a calling package down there in China or download an app like TextNow and pick a local number to where you live. Then while you're connected to WiFi or if you can pick up a data SIM, you can make unlimited calls and texts back to Canada FREE!
Meow
Unfortunately NO. PM does not provide service outside of NA continent.
Consider getting one of free VOIP app which provide SMS/Call world-wide.
