data not working
gravityfeeder
I was overseas for a couple of months on my return too Canada I find that I can make calls with my phone but my phone does not recognize my Public Mobile data. A screen pops up and says that I have no data. I am paid up, data is turned on and as far as I know nothing has changed with my phone?
7 REPLIES 7
@gravityfeeder wrote:
I set the APN to Telus, problem persists
@gravityfeeder , this is the Public Mobile APN settings.  Make sure your selection matches it.  If there is no identical option for selection, then manually create a new APN.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
gravityfeeder
I think that I tried that as well, not sure. I did set the APN to Telus
gravityfeeder
gravityfeeder
I tried that, no success
will13am
@gravityfeeder , by chance did you do a manual APN selection while using your phone overseas?  I am guessing that your phone is pointing to an incorrect APN which will affect data but not calls.
HI @gravityfeeder
but voice calls work?
try Reset All Networks on our phone
eddieO
@gravityfeeder, try toggling your airplane mode off and then back on, also check that you have your data turned on in the settings.
