03-15-2023 12:05 PM
How do I know if my phone is compatible with VoLTE? I have Android, Moto G6.
03-17-2023 01:30 AM - edited 03-17-2023 01:31 AM
@Nezgar wrote:
@softech wrote:The VoLTE compatible phones listed on PM page is not the full list, there are phones that are not on the list but has VoLTE working.
Indeed! Happy to see this for mine... I sent a pretty please to CS Agents maybe they can "turn me on" ahead of schedule. 🙂
Model: KEYone BBB100-1
Your phone is compatible.
This phone will work on the TELUS VoLTE network.
This type of network change at carriers has traditionally been a provisioning update. It's not really a matter of if they can do it but if they will do it.
03-17-2023 01:19 AM - edited 03-17-2023 01:20 AM
03-16-2023 09:06 AM
@EdN what brand and model is your phone?
03-16-2023 08:56 AM
I did the check using the IMEI, looks like my phone is not compatible, thanks for all the info
03-16-2023 08:53 AM
Hi, thanks, shows I have an IMSI number and voice network type is LTE. Not quite what you had said but this is an older phone. Is it the same as VoLTE?
03-15-2023 01:18 PM
@EdN , the Telus site has a VoLTE checker. The checker seems to be rather "generous" with screening devices as some may be confirmed compatible but is not.
https://www.telus.com/en/support/article/how-to-use-volte
As for whether VoLTE has been enabled in your account, you can dial the following sequence *#*#4636#*#* to bring up a hidden menu. Look for IMS status. You want IMS to be registered and Voice over LTE to be enabled.
03-15-2023 01:04 PM
4G/LTE are available on PM and your Moto G6 is compatible with PM.
Here is the specs on your phone:
03-15-2023 12:07 PM - edited 03-15-2023 12:08 PM
let gogle be your friend.
added....
