Public Mobile Menu HyperlInks?
mpcdesign
Is it just me, when I click any of the Public Menu Hyperlinks, it takes me to a French website.
The links affected is the logo, Plans, Get Started and Get Help. There were a few other links within the site links too. But gave up, because I can't understand Francais!?
CraftyFarmer
Its because you asked someone for help! Isn't that always the way? You can't get something working, and ask a friend who gets it on the first try and thinks you're just out to lunch
mpcdesign
Before I posted this message, I tried all that was suggested, to no avail. It happened yesterday.  That's when I posted seeing if anyone else had this.
Now, for some strange reason, when I click on the menu hyperlinks, guess what, it's now English!
I must be losing my mind, smoking crack, drunk, high or tired. Either that, it's a sign that's telling learn French with your kids!
[Self solution accepted today 🤣 .......  Luddite]
Staliger
@mpcdesign yes, that's because for some reason, your IP is french by default. You need to restart your modem/wifi router as was previously mentioned.
BearFBI
@mpcdesign When browsing Google or anywhere else do you see french search results or other webpages in french ? If so then @cavemantoronto is right. This happend to me before. Google thought my IP was French. I had to make google fix it directly because my ISP offers almost free static IP's and Ive had my IP for 3 years. I didnt want to loose it. Try browsing on your mobile data.
zblackma
@mpcdesignTry clearing your browser history and restarting it. You can also restart your device.
cavemantoronto
Restart modem to get new IP address.  The IP might be making site think you are in French speaking region of country. You can change langage to EN/province at top.
