Public Mobile APN setting not working on LG G4
souvik126
My LG G3 was working fine with data but I upgraded to LG G4 and used the same below APN and it is not even connecting to data. I have data enabled and every setting seems to be correct. So if someone can help.
APN: sp.mb.com
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: not set
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
1 REPLY 1
Luddite
There have been reports here that this issue with the LG G4 is only resolved by performimg a factory reset. If you decide to try that be sure to create a backup so you can recover all your photos, contacts etc.
Good luck.
