09-20-2016 01:27 PM - edited 01-04-2022 01:02 PM
Hi,
I was previously on the
$120 90 day, Unlimited province wide calling, Canada Text, 4GB Data.
When the new plans were out I went through Self serve to change my plan on the next renewal date.
That date was today and funds have been charged to my card.
Problem is that it still shows me on the same old plan.
Here is the plan I was expecting:
90 day, Province-wide calling, Global text, 6GB Data
Please help.
My Account
04-04-2019 10:35 AM
Ha... Yes 😉
Thanks
All fixed now!!!
04-04-2019 10:33 AM
IT'S BEEN FIXED!!! MOD team is awesome!!!
Thanks everyone for all your help!!!
This newb is up and running properly now!!!
04-04-2019 10:26 AM
@Mayellah wrote:All unauthorized texts were sent to 474663
6:53
6:54
8:138:13
8:26
8:26
8:27
8:28
8:42
8:56
9:11
You can transfer this information to the moderator here...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 And patience waiting time is few hours to 2 days.
04-04-2019 10:23 AM
6:53
6:54
8:138:13
8:26
8:26
8:27
8:28
8:42
8:56
9:11
Again...this is not about Public Mobile. That is your phone doing some initial set up with iMessage and iCloud and whatnot.
04-04-2019 10:21 AM
6:53
6:54
8:13
8:13
8:26
8:26
8:27
8:28
8:42
8:56
9:11
04-04-2019 10:16 AM - edited 04-04-2019 10:21 AM
@Mayellah wrote:
Maybe figure out the money and then figure out your data. Something doesn't look right with that anyway. Unless you bought a data add-on while on the $10 plan...the $10 plan doesn't include data. Unless you're wanting to do picture messaging.
Edit: Since you've figured out screenshots...maybe post one of your overview page. Blank out personal info of course.
Edit again: And since this looks like an iphone...have a look here.
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
04-04-2019 10:10 AM
This is what it currently is
04-04-2019 10:00 AM
A couple things:
The "unauthorized texts" are not Public Mobile. They're your phone doing some initial set up.
So you started out with the $10 plan and then ported...did the port finish successfully?
Then you seemed to have intended to change immediately to the $25 plan. Is the $25 in your Available Funds? As already mentioned, if you successfully change to a different plan before the original plan ends then you would lose the $10 you had already paid and there are no refunds or pro-rating here.
04-04-2019 03:07 AM
04-04-2019 03:04 AM
Yup... But was already charged the $25
04-04-2019 03:02 AM
Does your self serve still show you are on the 10$ plan?
04-04-2019 03:01 AM
I don’t sleep... 😂
And these issues don’t help!!! Once my plan is updated to the $25, I won’t have to worry.
04-04-2019 02:47 AM
@Mayellah wrote:Really? Sending unauthorized texts? Hope my plan gets rectified soon!!!
@Mayellah You go to your Account and check your status and what plan that you are currenting in. Don't panic. Just wait and get rest soon.
Just a recommendation: There are free apps online that you can call and text within North America for FREE. I like TextNow for it covers all areas within Canada (Fongo doesn't). You have a unique number and voicemail too. But you have to use it with wifi or data. I saved a lot of money while using them.
04-04-2019 02:42 AM
04-04-2019 02:42 AM
@Mayellah wrote:I bought my SIM $10 in store
I activates a $10 plan ( to Make sure I got service ) prior to porting my number.
Once I saw I had service, I ported my number and changed my plan to $25 .
I was charged for both plans.
@Mayellah You need to set up your APN in order to use your data. Click the following link and select the android phone or iPhone model:
https://www.publicmobile.ca/en/bc/get-help/articles?q=apn
Welcome to PM! Good night...
04-04-2019 02:37 AM
04-04-2019 02:37 AM
What plan did you change to?..being charged again iswhat happens on an immediate plan change..as for used texts phones send messages to apple and google once they register on a new service
04-04-2019 02:36 AM
@sunflowershine wrote:
@Mayellah wrote:I had a $10 plan as I just signed up and wanted to make sure I got service. Within 15 minutes of porting my old number, I changed plans and was charged. However that update doesn’t show on my account.
Also, my text message usage is blowing up and I haven’t even used 1 outgoing yet...
@Mayellah Seems that you just newly activated your SIM and make a payment first, Because you tried to port your old number, you are charged $10 again. Is that right?
@Mayellah You may want to contact the Moderator to see if they can give you a refund for that. You can simply click on the envelop icon (beside your sign-in logo) and send to "Moderator_Team". There is no guarantee. Sometimes the porting may take up to 2 days. You may be able to call out and texting. So you can keep your old SIM to receive call.
04-04-2019 02:29 AM
04-04-2019 02:25 AM
04-04-2019 02:22 AM
04-04-2019 02:18 AM
I’m having issues too with my plan. Can anyone help?
Thanks
10-11-2016 09:47 AM
10-11-2016 09:35 AM
Thanks @Saray_O! All good now!
10-10-2016 09:50 AM
Hi @clubie,
I'm sorry about that. I have changed your plan for you! Could you reboot your phone so it recognizes the change? 🙂
10-10-2016 12:21 AM
10-09-2016 11:54 PM
Same issue here! I've PM'd you Mary-M
09-20-2016 01:32 PM
Hey @oshax
Thank you for reaching out to us!
Sorry to hear that your new plan change did not take effect. Don't worry, I have activated the new one!. Simply reboot your device and view your self-serve account; everything should be in order.
Do not hesitate to send me a message if you have any other inquiries.
