03-15-2023
07:07 PM
03-15-2023
07:35 PM
computergeek541
I had a problem still 1 week ago when I try to use the YouTube app with my data plan, It doesn’t work, and It works with my wifi, but not with my public mobile data plan.
03-17-2023 01:50 PM
Thanks, It work now. 👍
03-17-2023 10:52 AM
@Melodys are you on iPhone?
if you are, check the Cellular Data screen on your iPhone and make sure YouTube is toggle on, allow to use Mobile data
03-17-2023 10:49 AM
Just YouTube, but when I connect to mi Wifi it works well.
03-16-2023 11:37 AM
Was this resolved? What was the issue?
03-15-2023 08:05 PM
As mentioned by @hTideGnow @check your app settings to make sure YouTube is allowed to use cellular data.
03-15-2023 07:22 PM
Hi @Melodys
Does browser and other apps work? does it work with Wifi?
Check if Data saver is enabled
If iOS, check if you have the app restricted from using Mobile data, you might have set it by accident.
03-15-2023 07:20 PM
03-15-2023 07:15 PM
@Melodys Just YouTube? Have you been using it without problem??
Easy way is to clear cache.
Or you can also fully install and reinstall
03-15-2023 07:11 PM
Just youtube? Or any web page? Does the app have permission to use cell data?
