Problem 7B1
_Olena_L
1. When I’m trying to call someone I hear “7B1 your phone is not activated on a network”, but I can get calls and answer them, how can I fix that? P. s. I got this issue after I changed my plan
11 REPLIES 11
_Olena_L
I changed the subscription on renewal date
HI @_Olena_L renewed or updated last night?  it could be the problem.   you really need to submit ticket with agent and ask them to refresh your account
_Olena_L
No, $45 plan, and my plan was updated yesterday
DennyCrane
Are you out of minutes? The $15 plan has 100 outgoing minutes and unlimited incoming minutes.
_Olena_L
Thank you!
HI @_Olena_L
and you are not on $15 plans, right?
7B1 could also be network problem.  Would you be going out ? check your phone in another location.
And for workaroud, download TextNow and use it to make calls until issue is resolved
mojorising
_Olena_L
Thanks for your reply! I tried everything but it doesn’t work and I can’t contact a CS Agent. I need to submit the ticket before but I get error message each time I press submit the ticket.
_Olena_L
Thank you!
It doesn’t work anyway
@_Olena_L
reboot the phone first.  Then try call with a 1 in front of the 10ndigits number
mojorising
Try rebooting your device, resetting your network connections, toggle in airplane mode, on and off, and removing then re-inserting the Sim card in the device.
If problem is still there, contact a CS Agent at the address below.
