Prepaid SIM card
Stangmike03
I just purchased a PM SIM card from Walmart today. It’s not activated yet.   When I brought it home I noticed the packaging says it’s a prepaid SIM card.
I was planning on using it for the $25 500gb unlimited talk text plan.  Will it work for this or should I go back and get a different SIM card?
Alex888
@Stangmike03 All Public Mobile plans are prepaid and all use the same SIM cards. It just means that you pay for service at the beginning of the month before you can use it rather than at the end of the month.
Gregmt
As long as it is a Public Mobile SIM card you are good to activate any plan on the website . Public Mobile is very simple company no complicated things with it.
Lieux
No you are ok with this card. You can use it with the plan you want!!
sandpublic
Yes it will. PM is a prepaid service
