Pre authorization for payment
Navneet83
I want to update my credit card information for payments as the previous one has expired
@Navneet83
if you activate yourself online, a My Account login would have setup already.  If you activate long time ago in-store, then it is true that you might not have a My Account setup yet
Either way, please open ticket with PM Support to have them check and/or setup the account login for you
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Navneet83
I am unable to create the account for updating credit card information
Meow
Log in to your account and try not to make mistakes while filing out the form
walker1
@Navneet83 You can do that yourself from inside your account.
For better success, login to your account using a browser in incognito or private mode first.
