Network connection
barrysanand
Just inserted new sim card in my Samsung galaxy s20fe.  Manually entered the network settings and still no network connection. Help!!!!
22 REPLIES 22
@barrysanand wrote:
Problem solved!! Thanks to Dan at Public Mobile
self given solution removed
barrysanand
@barrysanand
reset your network settings
1. Open Settings>General Management>Reset
2. Tap Reset Network Settings>Tap Reset Settings
If prompted enter your pin, passcode
3. Tap Reset Settings 1 more time to confirm
4. Restart
barrysanand
I am sorry, but the I put in the wrong active sim card in my phone, so I am still in the same situation as before. No connection
barrysanand
Received Notification, I am connected
Thanks for your help
barrysanand
Received notification, All set
HI @barrysanand   Glad to know you are all setup
Enjoy
barrysanand
Just got notification, I am all set. Thanks for your help
barrysanand
Yes, Last night
barrysanand
Not a new phone Year old. Samsung Galaxy s20 FE
Also tried on old phone. No go
@barrysanand wrote:
Said yes to Telus.
Telus acknowledged.
Changed Sim
Still no network connection
HI @barrysanand   yes, you are dealing with 2 things
First, porting.  You replied YES.  Telus sim is not working, that is good.  Number should have been ported
Second, there is a problem with sim card setup on the system.  I believe you opened ticket with CS agent.  Wait for their reply  (But if you have not opened a ticket yet, then please open one)
barrysanand
I reinserted the Telus SIM back and nothing has happened. Please advise. I do need to have my phone up and running
@barrysanand wrote:
Said yes to Telus.
Telus acknowledged.
Changed Sim
This is no fault of your own, and while this may sound counter intuitive, replying to Telus an authorizing the number port was actually a mistake.  This is because when there is no service on the Public Mobile service, this issue is unrelated to nubmer porting.  Unfortunately, authorizing the number port would have only transferred your phone number over to a service that doesn't work.  The Public Mobile service should have been working (less incoming communications) before the porting was finalized.  I would suggest re-inserting your old Telus Mobility SIM card to see if that service is still working (if would be if the number porting never finished).
HI @barrysanand   the no network connection is because of the sim card setup
You have to wait for PM CS Agent to reply your ticket.  Please look for your Community inbox for their reply
barrysanand
Said yes to Telus.
Telus acknowledged.
Changed Sim
@barrysanand wrote:
Received message from Telus asking permission to switch after ticket submittedd
HI @barrysanand
so, you just activated and requested porting?
you replied Yes to Telus text?  If you did, now put the PM sim card in a phone , can you make outbound calls?
barrysanand
hairbag1
@barrysanand...
Help us Help you. Please respond to the help you've been given so far.
If your phone started working...let us know. Otherwise we won't know how to help the next guy that has same issue as you.
HI@barrysanand
This is a new sim card and not new activation?
If this is a new sim card and you are replacing old one, make sure you go to My Account and Change sim card there first
If you have done that already but it is not connecting at all, it would be the sim card not properly setup or provisioned on the system.
Please don't wait, open ticket with CS agent and they will fix it for you
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
hairbag1
So....did you activate your new plan ?
Yummy
If phone is brand new I would recommend factory reset.
Can you try your SIM in another phone?
Is your account active?
Try to manually set Network Operators to PM.
Quigley
@barrysanand   Have your phone choose the network automatically.. from settings on your phone.  Also try restarting your phone.
