Deadzones, slow speeds with full bars
JoshP83
Just migrated to Public. Noticing that I have a lot of deadzones in the lower mainland (greater Vancouver). This happens even when it is showing my connection has full or near full bars.
Running on a new Oneplus 12R made for North American market. Had no problems on Rogers prior to this.
9 REPLIES 9
hi @JoshP83
instead of auto switch, manually change to 4G and test.  In my experience, in some "weak zone", manually change network mode and pick the best network is better
JoshP83
This has been the most useful but did not completely solve my problem. It did improve it greatly though.
Cheers
JoshP83
Yes it's on auto switching
RavingRaven
@JoshP83 @vancouverstu97
Is this when your phone is in 5G? There are still many areas even in urban settings where 5G has not been fully deployed or it's signal is weak. The 4G LTE network is much more comprehensive.  Make sure your phone's network settings are on automatic so that they switch to the network with the strongest signal. You may need to toggle airplane mode on/off occasionally to re-establish the best connection to the network.
@hTideGnow wrote:
hi @JoshP83
Telus actually has great network in BC, better than Rogers
your problem is likely APN related.  OnePlus is picky with APN
please first make sure you have the latest OS.  Then Reset network settings could resolve it
if not, update APN as follow:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
Having dead zones is unrelated to APN settings.  Changes in APN settings cannot possibly cause a network to be unavailable, and while there are some type of priority settings for APN type, these settings are also highly unilkely to have any effect on data speeds.
hi @JoshP83
APN: sp.mb.com
MMS port: 8799
MCC: 302
MNC: 220
JoshP83
Maybe but my wife is on public with no issues, it's why I switched.
golfball
Telus network has spotty signal in BC.
slusagm
did you try Reset network settings?
