Potential scam...?
Barryere
Hi,
Normally I'd deal with things like this myself by either ignoring it, blocking it or if I'm in a mood respond to it and mess around with the person, but in this case given the context and literal secrecy implied, I figured I'd share this message publicly under the assumption that it is a scam of some sort and to raise awareness towards discarding such messages.
21 REPLIES 21
z10user4
@Barryere wrote:
Hi,
They just signed up 3 hours ago (now 9:57 ET at this writing) and this is how they start. Yeah...ignore. Thanks for the heads up.
will13am
I would definitely report this.  It seems rather suspicious.  Thanks for helping to raise awareness.
liuxinbing
I got exactly same thing this morning, I reported it to the MOD.
Barryere
I'm not keen on reporting anything but I did this once.
Barryere
They just sent me the same message again about 5 minutes ago, copied and pasted.
I just got the same thing so what can be done about it?
SD08
@Barryere  @RossN
Other than reporting them, you can add the user to your "Ignore" list. I believe that would block any further messages, though I haven't had occasion to try it myself. There are two ways to do this:
1) You can go to their profile and click "Ignore" which appears when you hover over the empty space underneath "Send this user a private message"
2) In the private message they sent you, click "Ignore" which appears when you hover over the empty space next to the message timestamp.
RossN
yes well that's all well and fine for those of us that can follow your directions but is there not someone here that can take away their privileges
@RossN,
If you still have the pm in your inbox, there is a 'Report' below the message on the left.  This should be all you need to do to report it to the correct people.
