Porting issues looking for number to call
Vegan798
Porting issues looking for number to call to accept the port for my number
7 REPLIES 7
@Alishajl wrote:
Porting In. She can make outbound calls just inbound calls go to voicemail.
@Alishajl  I can private message you the number
BUT.. you need to sort out the situation with your old provider.  It is whether your old provider agree to get your verbal  approval instead of via text.  They might be ok.  Or they might ask you to get a new sim card and tie to your account and then get the porting authentication text and reply YES.  This is something you need to sort out with yoru old provider, NOT PM.
Once you got it confirmed with the old provider, then you can call the PM porting them and ask them to retrigger the porting process
Alishajl
@Alishajl   is your mother porting in or porting out the line?
Alishajl
Hi there - I need this number as well. My mother lost her old phone so is unable to approve the transfer.
@Vegan798   are you porting in to PM?  if you are , did you provide PM the correct information for your old carrier?
if you are porting out, then you need to contact the new carrier
HALIMACS
@Vegan798
Are you porting here, or out elsewhere?
If out elsewhere, contact their porting assistance.
@Vegan798   if it is issue with Porting in, then yes, there is a number to call.
I will send you the number. Check your Community inbox
