Porting a number to another account
AnnOnymous
@CS_Agent
Hello,
I am unable to create a ticket as I am encountering an error message and therefore messaging here as per the instructions I received from the chat bot.
I would to port my number to another provider. I have attempted to do this but have been told by the new carrier that an error was encountered. Therefore, I am following up here to see if there is some way to resolve the issue.
Please note that afterwards I would like to continue using my Public Mobile account with a different number. However, if it is not possible to resolve this issue then I will not renew my Public Mobile subscription.
Thanks
@AnnOnymous if you still have PM account . You can change your number on your existing PM account up to 4x in a 30 day cycle for free here’s how . In your account profile page
Change # on profile tabs
AnnOnymous
Thanks for all of the helpful replies. I reached back out to the other carrier and after several more tries the sms message finally came through.
I was hoping to assign a new number to my existing PM account as I had an ongoing subscription but I take it that this is now gone.
HALIMACS
@AnnOnymous
What you're looking to do cannot be done.
Once you port your number, the account is permanently closed.   It cannot continue with a different number.
If your goal is to retain your own number with another provider, the key to them 'pulling' that number there is whether it was a number originally assigned by them in the first place.  If it wasn't, you're out of luck.
Your options are, therefore:
  1. port your number to another provider, keep the number there, your PM account is kaput
  2. change your number here, in hopes that another provider can successfully draw that number for the service there (consult with them first), then your existing PM account remains active with the changed number
  3. stay with Public Mobile
Phil_Adelphus
"Please note that afterwards I would like to continue using my Public Mobile account with a different number. However, if it is not possible to resolve this issue then I will not renew my Public Mobile subscription."
Once you port out your number your Public Mobile account will automatically close.  You can always start a new one with a different number although you will have lost the rewards/points from the previous account
hi @AnnOnymous ask your new carrier if any issue with the phone number itself. Some numbers cannot be ported into some carriers.
also, you provide them your PM account number? it is better to give them account number
if you really need PM agent help, submit ticket here
@AnnOnymous  You just. Need to make sure your PM account is active and start the port with new carrier leaving the PM SIM card in phone to reply YES to the confirmation text PM will send you to port . But here’s link to support
send a  private message   To CS_Agents click
