06-07-2023 03:24 PM
I went to the transfer phone numer page and put in my Petro-Mobility number, it says "Phone number not eligible for port". That's it, or there is a solution to this problem?
06-09-2023 09:01 PM
06-09-2023 04:56 PM - edited 06-09-2023 04:57 PM
Thanks @esjliv
Now when I get to the second page of number transfer it asks me to "Select Your Old Mobile Service Provider".
Petro-Canada Mobility is not on the list, would some other name from the list suffice?
06-07-2023 03:28 PM - edited 06-07-2023 03:29 PM
@ElenaSt Check to see if your number can be ported from this Koodo website (Telus owns Koodo and Public Mobile), so, same allowances here: https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
If the number is portable to Public, choose the provider Ztar mobile.
Edit to add a post with more details about this from @popping : https://productioncommunity.publicmobile.ca/t5/Get-Support/Porting-number-from-Speakout-Apply-also-t...
