12-09-2024 10:39 AM
12-09-2024 10:43 AM
How long did you port over? It can take a few hours for the port to be completed.
Did you answer "yes" to your previous carrier port request confirmation text?
Are you able to use data? What about incoming texts or voice calls?
12-09-2024 10:42 AM
HI @Nimy
was it over a month ago that you requested port? if it was over a month ago, did you get a text from the old carrier for the approval of the port and did you reply Yes? If no reply for a month, the port would be cancelled and PM will assign you another number
You can check with PM porting support team for the port status. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
