Port issue - Can't receive phone call and no moderator response
06-21-2018 12:40 PM - edited 01-04-2022 06:14 PM
I just port my 2 phone numbers from fido to public mobile and now I can't received calls.
But I can dial out and send text. I have send PM to moderator but no response.
Hope someone can resolve this for me.
Joining Public
06-21-2018 03:41 PM
Issue is resolved with the moderator.
Thanks everyone for your support.
06-21-2018 02:36 PM
You haven't said if these are mobile numbers, or landline / voip numbers.
There is a signifigant delay for the latter. Days actually.
However, if you haven't sent a PM to the moderator+_team, please do so, but not, as there is a promo, response times will be longer than normal (we've experienced this before on other promos)
06-21-2018 02:07 PM
It has been over 15 hours after porting. But still can't receive phone call.
Anyone know when will the moderator response to message?
I have sent message to moderator for few hours already. But still no response.
06-21-2018 01:52 PM
I already tried what you said before and my mobile network is showing public mobile.
06-21-2018 01:05 PM - edited 06-21-2018 01:11 PM
It took about 2 hours for my port to be completed. The following steps might help:
-Reboot your phone
-Power off your phone and remove the SIM. Re-insert and power on
-Go into your phone's Cellular Network settings and manually select Public Mobile as your Network Operator.
06-21-2018 12:59 PM
Hi @THnewuser,
If you just started the port for your phone lines, the process may take a few hours to complete.
