03-22-2024
02:36 PM
03-22-2024
10:30 PM
computergeek541
Hello, it seems to be that I have an issue with my ported in number. I am not able to receive any calls or texts, but outgoing works with no issues. The old providers sim card is no longer working. Please help.
03-22-2024 02:45 PM
Seems like data and all outgoing texts/calls are working. Just not incoming.
03-22-2024 02:38 PM
HI @pacman8921
if old carrier sim no longer working, the port was done
your problem is the account not completely setup yet. Please ask support agent to check
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
