Pop up
Munirabdelwasie
  • I am tryimg to activate my data as it is over and i am trying to contact customer support but it is not working
8 REPLIES 8
Webb
Hi Webb here:
You are on Public Mobile for your cell phone and that is like using a low-cost airline. You just don't get anything for nothing. Soon low-cost airlines will probably ask customers to bring their own wings. At Public Mobile there is no customer service. Their virtual assistant is crap, and the community consists of a collection of users who only answers to problems is similar to throwing spaghetti at a wall just to see what sticks. If you want real human contact that cares about your problem, you won't find it at Public Mobile. Best of luck to you.
DW
Munirabdelwasie
Yes i did it is not working
@Munirabdelwasie
Did you try login to your account and purchase additional data in Purchase Add-ons.
HI @Munirabdelwasie   buying add-ons requires 2 separate steps, first to load fund , then buying the add-on
did you do both?  remember, people click on buying but then it brings you to load fund.  After fund is loaded, you still need to go back and buy.  It's troublesome
So, check if you did both steps
HI @Munirabdelwasie   Help for Pop up?  or you meant Add-on ?
Maybe let us know what problem you have and we will try to help.
It is usually quicker to get an answer from the Community then via PM CS Agent
But if you need to open ticket, here you are:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
MrSpock
@Munirabdelwasie you will need to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
MrSpock
@Munirabdelwasie hi are you trying to buy a data add on? it is a 2 step process first put money in your account and then go back in and buy it , to speak to a customer service agent   you will need to open a ticket   Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
Munirabdelwasie
need to get support ASAP
