Sunday
I need to cancel my daughter's account as the phone was stolen.
I xant sign in without verification code..what do I do?
Sunday
Have the 2FA code sent to her registered email or voicemail. Then go to Account-Report Lost/Stolen Device. This will pause service on her stolen phone until she gets a new phone and SIM.
If you decides to cancel service. She will loss your number and the SIM will no longer work.
It is better to pause service once she gets a new phone and SIM. Go to Account-Change Your SIM Card…this will retain her current number.
Sunday
HI @TyTy85
you don't have to cancel the account. Get a new PM sim card from Telus or Koodo store and login to update the sim card number and that will solve the problem and avoid the phone being used
but to cancel or to update the account, you need to login. Click Didn't Receive code or Resend code and see if you have Send Email or Send voice message option (with send voice message, call yourself using another phone to retrieve Voicemail)
If those option not there, ask PM support agent to help. Submit an Expert Messaging ticket (Use a different email address to create another Community account and submit the ticket with this new account): https://expert-messaging.publicmobile.ca/guest/chat/
At the Chat, type "Submit Ticket", then type "Connect Agent", and type "Connect Agent" again. Then login to open ticket
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
Remember: Support hours of operation: 9 AM to 10 PM ET
Sunday
you can disable Autopay from My Account - > Payment -> Manage Subscription
If you don't get the 2FA text when login, click Didn't Receive code or Resend code and choose to receive via email or voicemail (call daughter's number using another phone to retrieve the voicemail mail)
But if you still cannot get the code, then use another email to create another Community account to open ticket using Expert Messaging using this link: https://expert-messaging.publicmobile.ca/guest/chat/
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
