07-10-2023 02:29 PM - last edited on 07-10-2023 06:40 PM by computergeek541
Please help me how to check my voice mail in my phone, in my key pad there is no voice mail icon below 1
07-10-2023 02:39 PM
HI @Alansiva
Press and Hold 1 should work
if not , Reset all networks on your phone and the system will program the VM number on your quick dail 1, then you can press and hold 1 again and it will work
07-10-2023 02:35 PM
https://www.publicmobile.ca/en/bc/get-help/articles/voicemail-faqs
How To Set Up Your Voicemail Greeting
Your voicemail is automatically ready to accept messages. Until you set up your voicemail greeting, the default system greeting will be played. To set up your greeting:
How To Retrieve Messages
To retrieve your voicemail messages from your phone you can either:
Note:
How To Access Your Voicemail From Another Phone
07-10-2023 02:31 PM
Can you just keep your finger touching the 1? Press and hold?
07-10-2023 02:31 PM
try dialing your own number.
