03-24-2022 04:12 PM - last edited on 03-25-2022 02:17 AM by computergeek541
my Samsung S7 can send text message but can not receive text message , all phone and other function is fine .
it just happened a couple days ago , before that it was fine .
Thanks
03-24-2022 07:16 PM
yes I'm in Edmonton , In the past sometimes I got message 4 or 5 days late . but this time is worst , no text at all .
03-24-2022 06:32 PM
@Peter123 glad it works. Any chance you are in Edmonton area? We have another person with the same issue there. Just wondering if it is a regional issue.
03-24-2022 05:50 PM
Thanks , many thanks . putting my SIM to other phone then put it back to my phone fixed the problem . Now I've just received the first text in the last 4 days 🙂
03-24-2022 05:32 PM - edited 03-24-2022 05:33 PM
@Peter123 do you have another phone around? If so, try your PM SIM on the other phone. That could trigger a reprovisioning and it could resolve your issue.
If that still fails, probably it is time to open ticket with PM Support and they can reprovision from the system
03-24-2022 05:30 PM
Thanks, my plan is unlimited , rebooting many times still not working .
03-24-2022 05:22 PM
thanks , still the same .
03-24-2022 05:16 PM - edited 03-24-2022 05:36 PM
Do you have another phone try place your PM SIM? If it works then it narrows down to an issue with your phone.
If your account is Active and if you are on the $15/month plan and the is data left in your account.
Try rebooting the phone by powering off then back on again.
03-24-2022 05:13 PM
Ensure your “chat” (Android) or “iMessage” (iPhone) settings are turned off so that your messaging service relies only on SMS.
03-24-2022 05:12 PM
try off phone and take out sim card and put it back
or selecting network "3G only" or WCDMA only,
and rebooting device.
03-24-2022 04:22 PM
my data setting is "on"
03-24-2022 04:19 PM - edited 03-24-2022 04:20 PM
@Peter123 Make sure your data hasn't been turned off. It is required to send and receive MMS, though they don't count towards your data usage.
Alternatively try this:
Clear the Messages app's cache and data. Head to Settings > Apps > Messages > Storage > Clear Cache. After clearing the cache, head back to the setting menu and select Clear Data this time. Then restart your device.
