Plans
CelticBoy
There is a plan currently $45 per month
Says get $2.25 per month rewards to that effect....
Does that mean plan price goes down $2.25 per month?
Current plan $40 per month, no rewards.....
Is it better cost wise to change to the $45?
Thank you ALL
Brian
8 REPLIES 8
CelticBoy
Thank you very much
CelticBoy
Thank you so much
dust2dust
Points accumulation for plans as of this writing sorted by $/gig : (if you like overdosing on data 🙂 )
PriceGigs$/gigcommentpointsstart12 months+ loyalty1 year12 months+ loyalty2 years12 months+ loyalty3 years12 months+ loyalty4 years1 year +periods3 years +periods
1501800.8390 day7.50530.001045.0030.001085.0030.0010125.0030.0010165.00 3
45500.90 2.25527.001042.0027.001079.0027.0010116.0027.0010153.001.3
55600.92 2.75533.001048.0033.001091.0033.0010134.0033.0010177.002.5
65601.08US roam3.25539.001054.0039.0010103.0039.0010152.0039.0010201.003.4
50401.25US roam2.50530.001045.0030.001085.0030.0010125.0030.0010165.002.0
40301.33new acct2.00524.001039.0024.001073.0024.0010107.0024.0010141.000.5
34201.70new acct1.70520.401035.4020.401065.8020.401096.2020.4010126.600.0
102601.7090 day5.10520.401035.4020.401065.8020.401096.2020.4010126.60 1
39201.95 1.95523.401038.4023.401071.8023.4010105.2023.4010138.600.3
25125.00 1.25515.001030.0015.001055.0015.001080.0015.0010105.000.0
150.2560.00 0.7559.001024.009.001043.009.001062.009.001081.000.0
Adding - added bit about new accounts
Meow
PM shows how much would you 'earn' in Points if you subscribe for that plan. You need at least 15 points to start exchanging them for $.
Plans plan will stay the same for each 30 days.
dust2dust
Notice the tricky marketing terms used. $2.25/month in points value. You don't get any reduction in cost. You earn points that you can accumulate to then reduce cost or buy add-ons.
As for plan value that's up to you. Since providers are all about selling data, calculate the best bang for the buck. The problem with that is how much do you want to spend?
hairbag1
@CelticBoy
as a new customer, you'll be enrolled in the Points reward program. Each time your account is renewed, you'll get a small percentage in that program and eventually you can buy add-ons or whatever.
https://www.publicmobile.ca/en/bc/get-help/articles/public-points
@CelticBoy
no, the 2.25 is for those who are on Public Points rewards program and that is given as points.  Once you collected to 15 points, you can redeem for $15 bill credit
So, in short, you still need to pay the full plan amount+tax and get the points back
Doudou16
Hi Brian,
I think it means that you will have back the $2.25 value in Public Mobile points each month, when you choose to activate the preauthorized payments.
