Plan
Raphael2003
How do i upgrade my plan to have more data
2 REPLIES 2
porcupine
go to my account then plans then choose your plan then make sure to pick on renewal date
@Raphael2003   My Account is now down, you will have to do this later if you are not in a rush
Login to My Account, go to Plan & Add-on page, then click Change my plan
there you can choose the plan you want, sorted into 2 tabs, 3G and 4G. To scroll down the list, use the yellow arrows on the far right (or at the bottom if it is mobile site)
https://selfserve.publicmobile.ca/en/account/plan/change-planhttps://selfserve.publicmobile.ca/en/account/plan/change-plan
