Log In Fail
KookCho
I can't seem to log into my account or reset password to update  my credit card info
@walker1 wrote:
Only PM support will be your friend, no one else?
Could be, I guess.
walker1
@KookCho Incognito mode or other browser should work.
If not PM support will be your friend,  please open ticket with them
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Yummy
Do not change password. If you did change it, wait 15-20 to try to log in.
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
walker1
@KookCho
Try again but using incognito or private mode.
