Plan on hold
BBark
  • Hi, I ordered a PM sim card for $10 plus a $29 subscription. After receiving the sim card and porting my number from previous provider, my account is on hold waiting for me to purchase a new subscription. Why can't I use the subscription I purchased when ordering the sim card? Do I need to pay double to get started?
2 REPLIES 2
fixin1
@BBark - Login and it will ask you to continue activation. Do it within the app.
Does the SIM card work?
And about that, no SIM = No Service.
If it doesn't work, please contact CS_Agent:
Submit a ticket via Chatbot:
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
hi @BBark something not right.  did you login using the same email you registered?? maybe ask support agent for help.  Please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
