05-03-2024 11:55 PM
I recently added the 3GB US add-on and enabled roaming. I have been able to roam in the states as expected, but when I check data usage on my profile I see no change.
Should I see it get updated? Will I end up having to add more later? Am I just using a similar roam like home feature like other competitors? Just concerned if/when data stops while I'm using GPS and travelling.
Thanks
05-04-2024 11:08 AM
I'll check it out with them. Thanks for your help in the matter.
05-04-2024 09:14 AM
@Brainfreze1 this is in fact weird. You don't have a CANADA-US plan, do you??
I would not wait, open ticket with PM support and have them to investigate further :
05-04-2024 09:09 AM - edited 05-04-2024 09:10 AM
Hi. Thanks for your response. I checked my stats in incognito for chrome, but it still doesn't show data usage on the US Add-on field. I'm actually seeing the data being used on my regular monthly subscription. I think I'll just let it use up to it's 3GB limit and see what happens. Thanks!
05-04-2024 01:51 AM
Many GPS apps have an off line mode. Just update the maps for the area you are in or going to. You won't get traffic info but you can still get directions if you lose data.
05-03-2024 11:57 PM
@Brainfreze1 if should update, should be an issue with app cache or browser cache. Best to check again using browser with Incognito mode to avoid cache problem
