07-06-2026 03:45 PM
07-06-2026 03:49 PM
check the usage yourself.
login using a browser with incognito mode, login My Account and check what the usage showing on the front page, there is a usage odometer
and also on the phone, make sure you disable mobile data usage limit
07-06-2026 03:47 PM - edited 07-06-2026 03:47 PM
@TCONBOY Login to your account and see the Usage details. It will show you how much data use used and left.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
