Plan expired
mattieu
i noticed my data wasnt working so i checked my selfserve to see that my “plan expired” and it was saying i didnt pay, i checked my bank and transaction history, and i did pay for it. i also noticed my data itself isnt working but i can still send/receive texts, and my data usage is being used even when my phone is put away. is there any way to fix this?
2 REPLIES 2
darlicious
@mattieu
Your account status will change back to active sometime in the next 3 hours....as mentioned has your data counter reset? Do you have your data limiter set on your phone? Try rebooting your phone.
@mattieu   If it is "Plan Expired" and not suspended, then it is still going through renewal.
Is voice call working? do you see the Mobile data counter reset to 0 already?
I would not touch at this point.
If voice is not working as well, maybe start a quick ticket with PM support and have them to look into the situation.
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
