a month ago
Hello - I am considering switching to Public Mobile and getting a Can-US-Mexico plan, but have a few questions. Does this plan allow unlimited calls and texts to/from all 3 countries as well as within all 3 countries. ie. when I'm in Mexico can I also make calls within Mexico? No matter where you are within these 3 countries it all works the same as if you're in Canada. Does Hotspot work? In Canada or in Mexico? Lastly, do I cancel my Rogers plan first and then switch? Or open a new Public account first before cancelling Rogers. I want to bring my Rogers phone number over. Thank you!
a month ago
@Zeab wrote:Great, thanks so much. do you know if Hotspot works on Public? There may be occasions when we're in Mexico and I'd like my partner to be able to hotspot to my phone.
Yes: hotspot works.
a month ago
a month ago
If you plan on moving to PM, just make sure that your phone is VoLTE compatible with the PM network. If you don't have VoLTE compatible phone, your voice services should be affected while traveling in the USA and also potentially in Canada.
https://www.publicmobile.ca/en/get-help/articles/volte
Also, FYI- Public mobile does not offer Wifi calling, call control or other international roaming (ie. outside Mexico and USA).
https://www.publicmobile.ca/en/get-help/articles/mex-subscription
a month ago
yes @Zeab
Canada-US-Mexico allows you to call and receive call to and from within this 3 countries.
don't cancel your Rogers if you want to port. Keep the Rogers account active. Then download PM app and use it to activate. After Payment step, put in porting information, which includes your Rogers phone number
Your Rogers account will be cancelled after the line is ported into PM
a month ago
DO NOT cancel your Rogers plan before signing up with PM. Your Rogers account needs to be active to port your number to another provider.
a month ago
@Zeab Yes the CAN/US/MEX plan can be used to call to and from all 3 countries using talk text and data . The plan has roaming built into it so no need to purchase anything extra . Just make sure you have data roaming turned on in phone setting when in the U.S. /MEX
