05-16-2025
12:12 PM
05-16-2025
12:17 PM
computergeek541
Hi -how do you access your add-on for US texting and calling when have already paid for it and then visit the US in a week?
05-16-2025 12:37 PM
Thanks everyone - I appreciate the help!
05-16-2025 12:35 PM
05-16-2025 12:35 PM
Thanks
05-16-2025 12:32 PM
You paid for it already? Next time it is better to buy only 1 or 2 days prior to start of trip as it will expire after 15 of purchase.
Also, what phone do you have? Without a VoLTE phone you might not be able to make phone calls as the US no longer has 3G in most if not all states.
05-16-2025 12:14 PM
hi @SFO
US roaming has a 15 days expiration, you don't buy early. Usually you buy a day before the trip or right on the day
when you are in US, enable Roaming data and make sure the phone connects to T-Mobile or AT&T or Verizon (manually connect if needed)
and you will see a text asking you to buy roaming when you are in US, you can ignore the text if you already go the roaming addon.
