a month ago
Hello,
I recently subscribed with Public Mobile for a plan via a ESim card. First the online assessment showed that my phone is compatible with Esim then when I was completing the subscription and activating my plan the app is telling me that my phone does not support ESims
a month ago
Hello @ Charbel85,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
a month ago
hi @Charbel85
what phone do you have?
Check your Sim Manager or Settings-> Cellular screen, the esim could have already installed there. If so, just enable it or Turn on this line and then Reset network settings
but if you really cannot get it going , check with PM support agent first. You can submit ticket by direct message:
a month ago
@Charbel85 which phone do you have?
If it's really not compatible, I would recommend buying a SIM card from Amazon. They have one for $4.99 with quick delivery.
You can check if any Telus/ Koodo/ Mobile Klink near you also sells them but very few of these stores carries the Public Mobile SIM cards anymore.
a month ago
@Charbel85 Check your phone settings sim manager it’s possible the eSIM already installed but need to be set to primary or if iPhone “turn on this line “ is toggled on and rebbot the phone and reset network settings also removing or disabling old providers sim . If still no luck contact support to help fix
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
