cancelling
ddd777
I am on the 57 $ plan which is paid every 3 months
I received an offer by sms which involves a change of subscription
I clicked yes by mistake, which will change my plan when the current plan ends, but I want to stay on the current plan. How?
hairbag1
@ddd777
were you able to find how to cancel your mistaken plan change ? Let us know and we can guide you.
hairbag1
@ddd777
Have you given thought to the offer to upgrade your plan ?
hi @ddd777
the change is actually a scheduled change, you have enough time to cancel it
wait 24 hours, login My Account, check Subscription & Add on page and you should see a plan change scheduled there.  You can then cancel it
or if you like, you can ask PM support agent to help to reverse it.   You can submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
