Plan did not change on renewal date
ericnicholas416
Anyone else have a problem with the Black Friday promotion of $40 with 15 gb ???
I clicked “Change plan on renewal date.” A few days after my renewal date I checked back and saw my plan was not changed and I was kept on my old plan.
mattthetechguy
I had the exact same issue and can confirm that it is just a caching issue. Using Incognito mode I'm able to see that my plan is switched successfully.
darlicious
@ericnicholas416
You can also look at your transaction history to see what your plan charges are:
  • 30 DAY PLAN.............$10
  • 15GB AT 4G SPEED...$30
HI @ericnicholas416 this My Account has lots of problem with cache
you can clear cache and relaunch browser before checking My Account
or you can use Private or  Incognito mode to check , you will then see the correct plan
Quigley
@ericnicholas416   To see your current plan information, please login to your account using a browser in incognito or private mode first.
You were probably looking at old cached information before.   Try again.
JK8
@ericnicholas416
You might be looking at a cached version. Clear your browser cache and history and open a new window in incognito.
