02-24-2023 08:28 AM
02-24-2023 09:31 AM - edited 02-24-2023 09:31 AM
A few things I would recommend when doing this:
The above options are being offered, because I, personally, tried to switch one of my folks and experienced that very same issue.
02-24-2023 08:32 AM - edited 02-24-2023 08:33 AM
@Rosaignelzi Sign in to self serve go to plan add on tab and change plan
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
also be sure to make plan change for next renewal so you don’t lose out on your current cycle
02-24-2023 08:29 AM
@Rosaignelzi simply login to My Account, go to Plan and Add-on page, click Change My plan
https://selfserve.publicmobile.ca/en/account/plan/change-plan
There, select your new plan from the 3G or 4G plans tab
Make sure you understand the difference between Change plan now vs Change plan on renewal date. Most people chose Change plan on renew date to save money
