add ons selection
lxh
we are going to travel in US around 2-3 days, what is the best add on about phone ?
We have the plan 20G data covers US/CAN/MAX, assuming canada phone wouldn't work in US, If we don't add-on.
Thanks!
@lxh
You might want to check if your phone is VoLTE compatible to work in the USA.
Enter the IMEI on the bottom of the link.
https://www.publicmobile.ca/en/on/get-help/articles/volte?_gl=1*1qks5fo*_gcl_aw*R0NMLjE3MzA4MTg5ODgu...
hairbag1
@lxh
When you get to US, you’ll get a text welcome to US and a nag to buy add on minutes. You can ignore that if you have Can / US plan.
will13am
@lxh , if you have a CAN-US-MX plan, then you are good to go.  No need to buy any add-ons.  The plan you have works the same in Canada, US or Mexico.  You can make/receive calls, text and use data.
