Plan change help!
soovin0115
I moved my mobile agency from public mobile to somewhere else yesterday,
and I so need to deactivate the public mobile plan.
I know that I can do so in my Accounts page, but I forgot my password.
So I tried finding password, but as I changed number, I can't receive security number through phone, and for some reason email doesn't work either.
I'm stuck where I can't go into my Account page, but I need to deactivate account. I wanted to call for customer service help, but I coudln't see any number for them either.
soovin0115
Thank you, everyone!!!!! Now I'm releived that I wouldn't be paying two mobile service companies
Quigley
@soovin0115
If you still had your credit card information on file in your account, before you ported out your phone number,  you should really try to have a CSA remove that information totally.  Just for peace of mind. But it's up to you, if you like to gamble.
hi @Meow you are all good.  it is a good sign you cannot log in, it means account closed
Just monitor your credit card, but OM won't charge you any more
Meow
If you ported out / transferred number to other provider your account is Closed permanently. And you cannot log in anymore as account does not exist anymore.
JK8
@soovin0115
If you successfully ported your number out then your PM account is automatically closed.
Outdoorsman
@soovin0115 hi once you port your number your account is automatically closed therefor you can't get into it because public closes it for you
