Plan Deactivated need to restart
Yeolesuvarna
Hi my plan was deactivated due to 90 days inactivity, I need to restart it. If this reaches a public mobile employee, I would like to reactivate my account.
9 REPLIES 9
Naepalm
@Yeolesuvarna
Sorry but you are out of luck on this one. Sad part is you may have lost any rewards you had.
Youll have to buy a new SIM and activate it.
hope all goes well.
Naepalm
@Pawprints1986
Only for new as always.....but we might get a summer bonus at some point!
Pawprints1986
@darlicious just curious, likely promo just for new or for existing as well?
kselmak
@Yeolesuvarna
Sorry but your account is gone forever.
Was the number originally with public mobile?
If not, it went to the original provider.
If yes, it may still be available
@Staliger  et al
FYI: email from a closed account can now be used to activate a new plan.
However, it cannot be used to change the username of an active, or suspended, account.
darlicious
@Yeolesuvarna
After 90 days your plan is cancelled. You will have to get a new sim, activate it with a new plan and a new phone number. There might be a promo soon though so keep an eye out for that.
geopublic
@Yeolesuvarna  Unfortunately after 90 days the account gets deactivated from the system and cannot be re-activated. You will need to signup as a new customer using a new sim card and email or email alias of the one that was used with the expired account.
gblackma
Sorry @Yeolesuvarna once the plan is closed. You have to restart with a new SIM and email address and make a new account. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Staliger
@Yeolesuvarna After 90 days, you account is gone. You need to buy a new SIM and register it with a new account and email.
