12-09-2022 01:32 PM
I was on the 250 MB plan and then I upgraded to the 1GB 3G speed. I've been charged $25 for the last two months and I'm just realizing that my profile still show my current plan as the $15. My plan usage tab shows the $15 plan.
What is going on?
Payment
12-10-2022 10:32 AM
I am having this problem too, except it's 6gb to 20gb of data...
12-09-2022 01:46 PM
Yes, but if have a calling minutes add on you'll still be able to call out beyond the 100 minutes outgoing call limit.
So you still won't know if you're still on the $15 plan or not. Just saying.
12-09-2022 01:41 PM
If you use phone a lot you will see which plan you have if you cannot call out after 100 minutes.
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-09-2022 01:37 PM
Restart you phone if no avail, Create a support ticket to get CS Agent to update your account. Good luck.
12-09-2022 01:37 PM
Log in again but clear your browser cache and open a new browser window in incognito. You are probably looking at a cached version.
12-09-2022 01:36 PM
Click on all the little spinner refresh icons lower down that you see and/or use private mode to make sure you're seeing updated information. The site is terrible at caching old information. Terrible
