Pixel eSIM transfer tool
Hi all
https://www.androidpolice.com/google-esim-transfer-tool/
yes,  Pixel only for now,  but does that mean no more $5 new esim for new phone?
and this article said it can convert physical sim to esim,  so, technically i have put one as esim on one phone and use the physical sim on second phone? ( yes, I know one active phone at a ti time, but does that mean I turn off one of them and I can use the other one?)
And I heard iPhone can keep the esim on the phone's special partition before the phone is wiped and re-setup, but it depends if carriers support this feature.   So, does PM or Telus support that??
2 REPLIES 2
Sansan
I guess you have the ability to turn one off and turn the other on in order to use.? Flexibility I guess. I would hope that Telus will support as one of the adds within the text is from them. Will be interesting to see...
