Pixel 3a service not working and phone barely working
bappo
My pixel 3a is not working as intended. I bought a new sim tray because my mom lost mine and the new sim tray came in but the phone is not making calls and not functioning properly, any ideas?
bappo
I reseated the sim tray and it just works all the sudden, i swear i tried doing that so many times, thanks for the help guys
@bappo  Also if your phone supports eSIM you can buy one in the PM app go to subscription add on page . Notice shop SIM card at the bottom of page click it and choose eSIM download and install
bappo
I probably should, I'll ask a friend to test it for me asap
bappo
I haven't tried using the sim in another phone but the sim tray size thing sounds plausible. How would i go about fixing that though
@bappo  and the sim still working on another phone?
so, you see the phone saying not connect to the network a lot with this tray?
I imagine the sim tray you got, the size is off a bit, maybe not pushing the sim to touch the connection.
@bappo  Can you try the SIM card in another phone to test . Maybe you damaged the SIM card while waiting for nee sim tray . If I’m you need a new SIM card maybe call around to local Telus Koodo store for availability or order from Amazon and you can som card swap it in your profile tap
SIM  SWAPPING  profile tabs
Note only do this on lap top or computer/ not mobile device
